SmallBrook Harlequin
Mozzer
Interests: Model railway all scales
Postby Mozzer » Mon Feb 09, 2015 9:37 am
Today I am starting building a Smallbrook Harlequin
So far I have cut of the Cylinders from the chassis & smoothed off the foot plate & ground the inside of the boiler so it fits
I have also started on the saddle tank as it has ballast in it this shows though the paint if notting is done to it so I have given it a coat of Halfords filler primer which will once dry have a light sand followed by a 2nd coat
here's whats in the box
100_7857 by Mozzer models, on Flickr
suffering from M.E/CFS since 2007
Re: SmallBrook Harlequin
Postby docnjoj » Mon Feb 09, 2015 3:02 pm
That is a fine looking kit! I look forward to the completion.
Postby Simon » Mon Feb 09, 2015 4:17 pm
I've a half done one sat on the shelf...will be watching with interest in the hope of getting inspired to finish it.
Mozzer
Postby Mozzer » Mon Feb 09, 2015 7:18 pm
I got on well but the saddle tank needs more work but that will be done tomorrow
All I have to do now is finish off the saddle tank & fit the handrails to it
I will post photos once I have had a Bath
Mozzer
Postby Mozzer » Mon Feb 09, 2015 9:40 pm
here are the photos
100_7858 by Mozzer models, on Flickr
Mozzer
Postby Mozzer » Mon Feb 09, 2015 9:41 pm
100_7859 by Mozzer models, on Flickr
Mozzer
Postby Mozzer » Mon Feb 09, 2015 9:42 pm
100_7860 by Mozzer models, on Flickr
Mozzer
100_7861 by Mozzer models, on Flickr
Mozzer
100_7862 by Mozzer models, on Flickr
Mark Goodwin
Postby Mark Goodwin » Tue Feb 10, 2015 1:27 am
Hi Mozzer,
I've built one of these before and you are right about the saddle tank ballast showing through if you don't primer/filler it first. Mike Rayner (Smallbrook Studios) has just released a 1/35th scale version called "Gold Crest". I think he's designed an enclosed cab for the 1/35 scale version. Here's the link:
http://www.smallbrookstudio.co.uk/produ ... it/9308312
I've got one and will start it once I've finished "Cock Robin", my first 1/35th scale. I'll post some photos in the "Size doesn't matter section" soon. I like this scale as the 1/35th cab on "Cock Robin" bears a strong resemblance to a Hunslet "Alice" port class.
It's great to see your building process and finishing - thanks for sharing them.
Warm regards
Mark
Pierre Chatelet
Postby Pierre Chatelet » Tue Feb 10, 2015 1:09 pm
Nice work ! :D
Last edited by Pierre Chatelet on Sat Feb 14, 2015 1:10 pm, edited 1 time in total.
Mozzer
Postby Mozzer » Wed Feb 11, 2015 11:09 am
primmer filler & sand
& on & on & on
Postby chris stockdale » Wed Feb 11, 2015 1:20 pm
Mozzer wrote:primmer filler & sand
& on & on & on
:lol:
PS It's a neat little loco. It'll be great when all that hard work is done.
Mozzer
Postby Mozzer » Wed Feb 11, 2015 3:13 pm
the saddle tank is done & is glued in place just have to fit the handrails
Mozzer
Postby Mozzer » Thu Feb 12, 2015 1:36 pm
Here's an update: the loco has now had its coat of primer & is drying out; here is a photo of it before it got painted.
100_7864 by Mozzer models, on Flickr
Mozzer
Postby Mozzer » Thu Feb 12, 2015 4:41 pm
Here are photos of the loco in primer
100_7869 by Mozzer models, on Flickr
Mozzer
Postby Mozzer » Wed Jun 03, 2015 7:53 am
been sent a photo by the customer now he has painted the loco
ImageSmallBrook Harlequin Gn15 by brian mosby, on Flickr
Postby docnjoj » Wed Jun 03, 2015 2:23 pm
That is one pretty loco!
Postby Simon » Thu Jun 04, 2015 8:01 pm
Is the lever the wrong way around? I only ask because I did mine exactly the same and then thought "hang on, shouldn't the trigger be in the finger side?" :lol:
Very nice built though - much neater than mine!
