Originally, the subject of this thread, was going to be viewed from the front only, but sometime ago, I had a change of plan and thought multiple viewpoints would work better. If you go back to the beginning of this thread, the centre of the pizza, is dominated by a building, which takes up most of the space. The building though is rectangular, sitting inside a circle, so although at the corners of the building, it is quite close to the tracks, partway along the walls, there is a bit of spare space. This allows something to be fitted to the rear of the building and I decided a potting bench would fit in with the theme of the nursery and farm shop. So here you go, this is as far as I have got so far, still more details and clutter to add, but it is coming together. Questions as always are welcome
