First attempt at Gn15
Phil
Interests: Gn15 since a few days, On30 otherwis
Postby Phil » Sun May 04, 2008 4:46 am
Hello everybody
New to the scale, I've just decided to try my hand at laying a bit of track. Had no spikes, so I had to cut stapples in 3, discarding the middle. A dab of black paint could help .... :D
Then I started a little shed for my soon-to-be loco
BTW, the crew's local is supposed to be a thatched roof old kind of inn. Any idea on how to model thatch in G?
Best Rgds
Phil
franckcombe
Postby franckcombe » Sun May 04, 2008 6:30 am
excellent start and welcome in gnscale world.
Postby DCRfan » Sun May 04, 2008 6:38 am
Phil,
Welcome. Your sleepers are amazing but you had better get some more framing in the engine shed before the council building inspector turns up :lol:
Postby Gerry Bullock » Sun May 04, 2008 8:03 am
Looks great Phil; for thatch take a look at bristles from a suitable household brush. If the head is wood you can more easily destroy it and remove the bunches of bristles.
Problem is you'll have to lay them as per a Thatcher's method - individually and pegged down. :wink: :lol:
Phil
Postby Phil » Sun May 04, 2008 8:46 am
Tks for the kind words, Gents.
Gerry, I've been thinking about the broom thing but that seemed a bit overscaled to me. Have you tried it?
Don't worry, DCRfan, the inspector will never turn up anymore. Smell that smell in the little stoove?
:lol: :lol: :lol: :lol:
Best rgds
Phil
dr5euss
Postby dr5euss » Sun May 04, 2008 9:22 am
Excellent start, Phil :D
What about Sisel string? I guess it's worth an experiment, ifyou have some lying around in the garden shed?
Phil
Postby Phil » Sun May 04, 2008 10:31 am
dr5euss wrote:Excellent start, Phil :D
Sound quite interesting, though I would think it always comes twisted. Bit of a tough job to get it straight I would say...
Best rgds
Phil
Phil
Postby Phil » Sun May 04, 2008 10:49 am
A quick shot of the still-under-construction diesel engine.
The pic is A/O yesterday; date shows default settings on the camera :D
Best rgds
Phil
Postby Gerry Bullock » Sun May 04, 2008 12:50 pm
I haven't used the brush bristles for thatch however I have some on the Salt Pan as reeds. As thatch can be both straw and water reed (the best material) the source phragmites communis can be 10-16mm in size therefore my household brush bristle fits the bill.
However if you want to simulate a straw thatch you'll need to look at paint brushes with a natural colour.
I made my reeds into 'bunches' using CA applied at one end to form the bunch.
Hope that helps.
I would avoid any man made strings as you'll Gnever get them straight.
Sorry George I think you'll find it doesn't work. :wink:
dr5euss
Postby dr5euss » Sun May 04, 2008 3:09 pm
Gerry Bullock wrote:Sorry George I think you'll find it doesn't work. :wink:
I've found some old stuff under the sink and it looks promising actually, if I get a few moments I might try it.
Dave Westall
Postby Dave Westall » Sun May 04, 2008 7:03 pm
I like your work Phil - look forward to seeing more of it. 8)
Dave
May your wheels never rust.
Postby Glen A » Sun May 04, 2008 8:21 pm
WOW Phil :shock:
That's amazing work.
Postby michael » Tue May 06, 2008 3:44 am
welcom Phil A nice bit of work on the track and the brick detail that is showing with the plaster spalled off.
Panda
Interests: model railway, mostly my layout, music, sailing, leaf sprung land rovers
Postby Panda » Wed May 07, 2008 6:56 pm
im inspired! im off to have a go.. eventually!
Peter-John Sanders (formally known as mogbass01)
http://drws-y-coed-railway.blogspot.com/
Stu
Interests: Narrow Gauge & US outline
Postby Stu » Wed May 07, 2008 7:07 pm
Nice bit of modelling Phil. How did you do that worn out wall?
Also, what scale wall light did you use?
A coffee table used for coffee is a waste of space!
Postby Willow Creek Traction » Thu May 08, 2008 2:26 am
Phil wrote:A quick shot of the still-under-construction diesel engine.
Hey There;
Metal for hood/bonnet ought to work well - will look good painted :D
Phil
Postby Phil » Thu May 08, 2008 6:51 am
Stu wrote:Nice bit of modelling Phil. How did you do that worn out wall?
Tks gents for all the kind words :oops:
Worn out wall started as plain cardboard, individual bricks cut from painted peeled foam core glued where they shud appear under the plaster and real plaster on top of all this. A thin wash of indian ink diluted in rubbing alcohol and voila.
As for the light, it's scratchbuilt (but the grain of wheat bulb :wink: ) from a cottage cheese box lid! (told u I kept my modelling on a low budget :D :D :D )
But I wasn't quite satisfied with it so I built another one from a piece of plastic turned on my mini drill used as a lathe, 1.5 mm copper wire and top of a precription capsule. Pics ASAP
Best Regards
Phil
andrew milner
Postby andrew milner » Fri May 09, 2008 5:22 pm
In the UK, we have 'pound shops' which sell paintbrushes which would probably be good for the thatch. I have straightened sisal string though for reeds. Just cut lengths, untwist as much as possible, soak in water, hang with a weight at bottom to stretch and let dry :D
Stu
Postby Stu » Fri May 09, 2008 6:39 pm
Now I know there are a few botanists amongst you lot, so maybe you can give this a common or scientific name!
It's a tall grass that normally grows wild in the countryside, it's about 18"-2' tall with a bud of fine seeds on top that look a little like a droopy corn. The stem is very rigid and I believe hollow although it is quite fine..
Now if you can work out what it is, the stems of this grass would be ideal for thatch..
Bob Taylor
Postby Bob Taylor » Fri May 09, 2008 8:10 pm
Hi Phil and welcome to the group.
Very impressed with your efforts. Great work. I really like your track. Looking forward to more postings.
Bob.
Gnine: Narrow your horizons!
Re: First attempt at Gn15
Postby Steve Bennett » Tue May 20, 2008 4:30 pm
Phil wrote:BTW, the crew's local is supposed to be a thatched roof old kind of inn. Any idea on how to model thatch in G?
Missed this question originally :roll:
Many years ago, I used coconut fibre brushes for thatch in 1:24. It worked very well, was also waterproof, which was useful as the buildings were for outdoors :) , not that you need that, of course.
The photo below, is not of my work, but that of my teacher. He wrote a book on the subject, Landscapes in Miniature, by John Canstable, published by Sheldon Press in 1984 (ISBN 0-85969-412-7) aimed at creating miniatures in the garden. Yes, the plants in the photo are real and this display piece was about 10 years old when photographed. The weathering on the thatch is completely natural.
Phil
Postby Phil » Tue May 20, 2008 5:01 pm
Steve,
That is not fair!!!!!
You posted a picture of your own cottage in Devon.
I'm trying to model in 1:24, not 1:1 :D :D :D
Best Regards
Phil
Postby Steve Bennett » Tue May 20, 2008 5:06 pm
Phil wrote:Steve,
Wish I could say it was mine :lol: it is a wonderful bit of 1:24 scale modelling.
My house is brick and tile unfortunately :( .
Postby Steve Bennett » Tue May 20, 2008 5:37 pm
Just to show that it is a real 1:24 model, here is the complete landscape with the builder. The cottage and garden are built in one tray and the background trees are grown in a seperate window box, which was placed behind for the photo's. Hope this translates ok Phil.
Dave Westall
Postby Dave Westall » Tue May 20, 2008 6:32 pm
Perhaps there is an idea in something like this for Gerry and his Bonsai.
Dave
