Something a little different!
Postby gfadvance » Tue Jan 05, 2010 4:31 pm
Hi , posting couple of picture of current project as much as anything to keep me going to actually finish it.
I know these as "steam" road rollers, although I apply this term to both Steam powered and internal combustion versions .... its an age thing.
Always liked these machines and thought that one of these might go with the crane and loco I have also been building, as I could not find any plans or even dimensions this is pretty freelance. Based very loosely on the Advance manufacturer, date around mid 20's to 30's and one of the smaller versions probable around 2 to 4 tons .... which seems how these machines are classed.
Image Image Image Image
You never know when you start these little projects where the real problems will arise, in this case I thought it would be the rollers but actually these turned out to be pretty simple - the body/chassis which I thought would be easy turned into a nightmare but am getting there now.
Michael .... sorry still using same figure , must, must paint some new ones!!!
Steve, built the box, thanks .... still sorting lighting :wink:
Postby Little Andi. » Tue Jan 05, 2010 5:04 pm
What a fantastic little project...... it certainly looks the part, carries itself very well and has a purposeful air about it.
I think you ought to expand on those "easy" rollers? - How about the front cradle/frame? - that looks pretty complicated - although very convincing. I think I can work out the rollers themselves - although did the surfaces come from a ready made tube or did you role them yourself?
Looking forward as ever to seeing where you take this........ you're certainly cranking out the projects......... I'm still stuck on the crane.
As ever........... fantastic job
Re: Something a little different!
Postby Willow Creek Traction » Tue Jan 05, 2010 5:10 pm
gfadvance wrote:... I thought it would be the rollers but actually these turned out to be pretty simple - the body/chassis which I thought would be easy turned into a nightmare...
That sure is a counter-intuitive situation :lol:
Postby dieselwater » Tue Jan 05, 2010 6:02 pm
Looks smashing Gordon :D Back in my old highway testing days, I used to go along behind a roller, not too dissimillar to yours, and check it had done a propper job of compacting the materials. I used a nuclear density metre for the job. Stand clear! Blasting! :shock: :lol:
kevinti28
Interests: GN15 and 7/8ths modeller
Postby kevinti28 » Tue Jan 05, 2010 6:52 pm
David
A nuclear densometer, wow ..... just before Christmas I was watching a good old fashioned sand replacement test.
That took me back thirty years to the early seventies, when I was digging holes in road sub base with a hammer and chisel, to carry out the same tests !!
Kevin
Change is inevitable ....... except from ticket machines.
Postby gfadvance » Tue Jan 05, 2010 6:53 pm
Hi Andi, blame your self for this one - the drilled outriggers on your crane was the look I was trying to achieve with the rollers on this one .. didn't get that close , in fact having posted the pictures not happy with the rear rollers, there's something wrong with them and will probably redo them.
Anyway the rollers are just wrapped paper round an appropriate former, with PVA so they shrink slightly as they dry then the outside was coated with superglue and then burnished with very fine wet & dry ... centres are discs of plasticard detailed with micro strip. etc.
Front cradle frame, think the eye deceives brain .... C channel plastruc, mitred corners with added strengthening plates and then corners rounded .... internal corners rounded with Swiss file to give bent channel effect. Vertical support plasticard then wrapped with outer piece to give
T channel effect ... swivel bearing plastic tube cut in half glued either side then pivot point drilled through vertical web... pictures may help make boring story slightly more exciting !!!
Image Image
foswaldy13
Postby foswaldy13 » Tue Jan 05, 2010 6:59 pm
Looks wonderful Gordon. The term Steam Roller is still prevalent here for these machines, even though they haven't been steam powered for more than half a century. I bet most people my age don't even question why they are called steamrollers.
Matt Oswald
Trevor Coburn
Postby Trevor Coburn » Tue Jan 05, 2010 7:43 pm
Looking good Gordon :D :D :D , please tell us there's a scale 2 pot Ruston* lurking under the hood...........................
(Gets coat & runs away :oops: )
*Ruston 2YDA, or Petter PH2, or ............
Trevor
Postby gfadvance » Tue Jan 05, 2010 8:26 pm
Hi Trevor,
actually don't know/ can't find much info on engine- info I first put on was badly worded, model is based on a Wallis & Steevens "Advance" model
All I can find about the engine was that it was petrol engined. h.p. ? cylinders ? (picture seems to indicate upright 2 cylinder but I would have thought it would need substantial flywheel - and where does that fit ?)
Was tempted to put a version of the Gmeinder engine in it Image
but too lazy ( paint job will improve, promise)
joe gilmartin
Road Roller
Postby joe gilmartin » Tue Jan 05, 2010 9:44 pm
Gordon ...
Great job on the roller and on the Gmeinder power plant
Have to go back to that Thread
joe
JH Gilmartin
Sole owner/operator
Moskito Coast Transfer Line
Postby DCRfan » Wed Jan 06, 2010 12:43 am
That is a really great piece of modelling. I imagine you have a real sense of achivement progressing this unsual subject. Well done.
Now somewhere I have seen a picture of a small German road roller fitted with hirail wheels that I believe was used to compact cobble stones on an urban passenger tram line. Would it be stretching it to too much on minimum gauge :P :P
Geeky Gecko
Interests: modelling in card
Postby Geeky Gecko » Wed Jan 06, 2010 7:10 am
Great modelling. Looking forward to seeing more.
Stefan
Postby michael » Wed Jan 06, 2010 8:14 am
Nicely done Gordon!
Postby gfadvance » Wed Jan 06, 2010 7:28 pm
Thanks for the feed back folks.
Having been snowed in today, had the time to add some details.
Few things to finish it off . mudguards for rear rollers, piping from rear water tank, steering wheel , etc. Still trying to decide as to whither or not I should add a roof or not?
Then this and the loco and crane will go off to the paint shop .......... seem to remember there is some deadline in February
Postby Gerry Bullock » Wed Jan 06, 2010 8:39 pm
Looking good Gordon; are you familiar with this Company?
http://www.prestonservices.co.uk/traction.htm
They have some road rollers for sale at present. :wink:
Their yard is remarkable, truly an Aladdin's Cave, anything steam so that includes NG Locos.
I note that currently they have a 15" Garratt for sale.
Les and myself spent several hours there some years ago. You do have to make up a plausible story to visit if you're not a buyer.
Nearby to where I live is the National Road Roller collection though I've never visited the place.
Postby DCRfan » Wed Jan 06, 2010 11:24 pm
Gerry Bullock wrote:Their yard is remarkable, truly an Aladdin's Cave, anything steam so that includes NG Locos.
Ex Bush Mill Railway Tasmania
Will Vale
Postby Will Vale » Thu Jan 07, 2010 12:51 am
More praise to add to the cavalcade - I think this is amazing, takes me back to going to the Hadnam traction engine rally a couple of fields down from ours when I was a tiny lad. Are you going to fill it with lead so it has 'scale' heft?
Thanks for posting the closeups and descriptions of the front roller, especially the tips on the cranked channel frame. I've been thinking about making some skips and this might come in very handy.
Will
Postby gfadvance » Fri Jan 08, 2010 6:27 pm
Gerry, thanks for the link.
Did come across their site when I was looking for information, in fact got most of my info/photos from them. Also tried to get some additional info from the National Road Roller Association but unfortunately they never replied to any of my e-mails.
Postby gfadvance » Sat Jan 09, 2010 9:38 pm
Roller heading for the paint shop, once painted steering wheel, control pedals and gearstick will be fixed in position
rockershovel
Postby rockershovel » Sat Jan 09, 2010 10:03 pm
this is what makes this such an interesting site - the range of people's interests
those rollers look like a serious amount of work.....
rambling miner
Rockley Bottom
Interests: NG railways
Postby Rockley Bottom » Sat Jan 09, 2010 10:47 pm
Great modelling :!: :!: very neat craftsmanship
Postby Willow Creek Traction » Sat Jan 09, 2010 10:50 pm
gfadvance wrote:Roller heading for the paint shop, once painted steering wheel, control pedals and gearstick will be fixed in position
8)
Is there a model built by anyone over 12 that does not have green putty? :wink:
JT Previa
Postby JT Previa » Mon Jan 11, 2010 3:37 am
I really like it! Very cool shape and believable details.
Nice work.
JT
Postby gfadvance » Thu Oct 27, 2011 4:37 pm
Trying to finish of "abandoned projects" so this one is actually nearing completion .............. where does the time go ?
At least its a change for Jon being able to decide where to go rather than just stuck on the rails
Booga
Interests: Narrow and minimum gauge railways, currently modelling O-16.5 but this site inspires me.
Postby Booga » Thu Oct 27, 2011 5:10 pm
Well worth the wait to see the finished thing, excellent work!
Jon can drive a steamroller too? That man has many talents! :wink:
Hello, I'm Dave.
So many modelling ideas, so little money!
Users browsing this forum: Bing [Bot] and 19 guests
