Grass and Weed
Mike Lee
Grass and Weed
Postby Mike Lee » Mon Sep 27, 2010 12:38 pm
Got this from another web site, looks a good idea, not seen it before.
http://www.youtube.com/watch?v=d2rOO1hN8_U
Regards Mike Lee
trefor
Interests: I am interested in railways generally. I have started making a layout, sort of 15" or possibly 18" gaugeish
Postby trefor » Mon Sep 27, 2010 12:49 pm
Very interesting. Thanks for posting this, I feel the urge to make a test piece coming on :)
Trefor
Postby Boghopper » Fri Oct 01, 2010 7:11 am
Thanks for posting the video clip Mike - most interesting. I would like to have a go at his technique on Duncton Yard, but I didn't recognise the spray adhesive he was using, I guess it's not available on the side of the pond. Can anyone suggest an English eqivalent which has instant and strong "grab" and dries fast?
Postby gfadvance » Fri Oct 01, 2010 8:59 am
Chris,
I normally use the spray adhesive available form B&Q, you will find it in the carpet section, Maplins also do a couple just make sure you get the standard version not the "reposition-able one"
Postby Boghopper » Fri Oct 01, 2010 12:20 pm
Thanks Gordon, I'll pick some up when I'm next over at the "sheds".
Dave freeman
Interests: 7MM NARROW GAUGE GN15
Postby Dave freeman » Sat Oct 02, 2010 2:08 pm
I bought some spray glue from the ever usefull poundland not tried it yet
DAVE
I'M ALWAYS IN IT . ITS JUST THE DEPTH THAT VARIES.
Will Vale
Postby Will Vale » Sun Oct 10, 2010 6:02 am
Thanks for posting this - I had some Super 77 in the scenery box, and I wasn't having much luck with the electric flyswat and longer (6mm) grass fibres.
It's certainly worth trying, especially for tussocky grass, although I've found I get some bald spots which need to be covered up with scatter. Looks good in profile though.
More here: http://www.rmweb.co.uk/community/index.php/blog/321/entry-4888-static-grass-experiments/
Sorry I haven't been on here much this year, I'm in standard gauge land at the mo...
Will
Postby PeterH » Sun Oct 10, 2010 11:33 pm
Your grass looks good Will. I tried the 6 mm fibers from the yellow bottle with holes in the lid and they did not stand up. I did find the fibers good for twiglets on trees - I put dots of PVA on the branches then drizzled the fibers on from my fingers and they spread apart OK.
What is the hairy fiber he used in the video ? (I have diallup here & where I watched the video there was no sound).
Will Vale
Postby Will Vale » Mon Oct 11, 2010 1:13 am
It was a cheap blonde Halloween wig, basically to save money on the fibres and make for longer strands than you can get commercially. I thought maybe it also helped form the cigars, but with a bit of practice they work fine with the shorter fibres.
Will
Users browsing this forum: Bing [Bot] and 15 guests
