Minimum Radius
bluey1989
Minimum Radius
Postby bluey1989 » Tue Nov 09, 2010 4:30 pm
No doubt this has been covered many times before but I cant seam to find anything.
I am looking to build a Gn15 pizza layout using peco 0-16.5 track and want to know what the minimum radius is for it (I have tried to get too tight radius' before so thought I would ask the question)
After posting the video of the loco with sound I need a layout to run it on...
Andy
franckcombe
Postby franckcombe » Tue Nov 09, 2010 5:28 pm
the answer is 6cm (2" 1/2) radius with a bachmann 040 davenport. It's easier to run with an heavy loco for a better electricity pick up. It's perhaps possible to do less.
In a true line, decauville with 40 cm gauge line (ie more than 15" line) had done a radius of 2meters which corresponded at scale at 3,33 cm !!
I have built a pizza layout to test a very small radius.
For more info you can go to my post http://forum.gn15.info/viewtopic.php?t= ... anck+combe
Postby Gerry Bullock » Wed Nov 10, 2010 8:27 am
Hi Andy,
Suggest you look here for Steve' advice:
http://forum.gn15.info/viewtopic.php?p=46200
For anyone looking at the points advice I suggest you pass, pm for further details.
Gavin Sowry
Postby Gavin Sowry » Thu Nov 11, 2010 6:36 am
8) Check out my 'Pizza 'n' Beer' thread, it's all in there.
Gavin Sowry
Gn15 Gnu Zealand
franckcombe
Postby franckcombe » Thu Nov 11, 2010 10:25 am
when I indicate a radius of 6 cm , it's perfect for loco but not for the rolling stock. The best way, is to make a test with your loco and your rolling stock on a flexible track line fixed on one side and bend on the other size and try various radius. make a test forward and backward you will avoid like that some troubles also. Take care on the way you link your rolling stock (ie pin and link, kadee, ...). I love pin and link (more prototypical) but kadee is far more reliable.
Postby Gerry Bullock » Thu Nov 11, 2010 10:52 am
franckcombe wrote:---------- Take care on the way you link your rolling stock (ie pin and link, kadee, ...). I love pin and link (more prototypical) but kadee is far more reliable.
If you use KDs you then have the ability to use a rooster which immediately enables smaller radius when using rolling stock.
franckcombe
Postby franckcombe » Tue Nov 08, 2011 6:42 am
I have built a pizza to test the minimum radius. The radius is 6cm and the 040 gas mechanical from bachmann runs perfectly but my other locos doesn't run well. You can forget with this radius to run wagon.
see my layout at http://forum.gn15.info/viewtopic.php?t=6318&highlight=
Gavin Sowry
Postby Gavin Sowry » Tue Nov 08, 2011 7:06 am
franckcombe wrote:I have built a pizza to test the minimum radius. The radius is 6cm and the 040 gas mechanical from bachmann runs perfectly but my other locos doesn't run well. You can forget with this radius to run wagon.
:lol: My Sidelines/Bachmann will haul Kadee coupled skips around 3½" radius (and keep doing it for 6 hours non stop.... Rail-Ex last weekend)
Gavin Sowry
Gn15 Gnu Zealand
Gavin Sowry
Postby Gavin Sowry » Tue Nov 08, 2011 7:11 am
franckcombe wrote:the answer is 6cm (2" 1/2) radius
:idea: After typing 2, hold down the ALT button while typing in 171, and when you release it 2½ will come up :!:
Gavin Sowry
Gn15 Gnu Zealand
