(F) Home-built Loco and small mine
Jim Snee
Interests: 15" and 18" steam
Postby Jim Snee » Thu Jan 05, 2012 5:06 pm
Here is a little "thingy" I found searching for grubenlok:
http://www.unbekannter-bergbau.de/inhalte/spot_13_003_Zschorlau.html
Anyone want to make sense of it?
Jim
MrPlantpot
Postby MrPlantpot » Thu Jan 05, 2012 5:33 pm
I love the 'loco' with two different sizes of wheel, hauling two buckets, and the CZ-Jawa engine (2 Stroke), that has to be kick started, and somehow put into 2nd gear, to run the winch...
'Old Folk Wisdom', where would we be today without it? :shock:
My Mum calls me Steve.
