SIDI FONTANA MOROCCO 1916 scale 1/72
franckcombe
Postby franckcombe » Mon Dec 08, 2014 6:55 am
I will start a new layout after the woolacombe bay and the nearly finished vestvagoy.
At an exhibition, a friend offered me these postcards
I wanted to do a layout based on these photos but at 1/13 scale it was not possible. So I choose to do that at 1/72 scale because at this scale there are french military figures and arabs too.
At Morocco in 1916, the french developed narrow gauge railways of 60 cm for civilian and military used. 60 cm at 1/72 scale is more of less 9mm, so I could used too the 009 material.
The layout will be an oval of 120 cm by 47 cm with an hidden part behind to finish the oval
The layout will look like more or less to that.
Re: SIDI FONTANA MOROCCO 1916 scale 1/72
Postby rue_d_etropal » Tue Dec 09, 2014 9:59 am
nice idea, if you had more room you could just as easily go for 1/35th scale, but 1/72 can be a big challenge, especially painting all those military figures.
Can we expect to see one of the big Decauville locos?
franckcombe
Postby franckcombe » Tue Dec 09, 2014 3:22 pm
I don't want to reporduction a meyer decauville because the radius is too big
Postby Nevadablue » Tue Dec 09, 2014 5:24 pm
This looks like it will be an interesting project. Watching! :D
franckcombe
Postby franckcombe » Sun Feb 21, 2016 7:24 am
If you want to order the luggage car you can click on
http://www.sculpteo.com/fr/print/fourgon-decauville-maroc-hoe/KEYSfuJy?basket=1&noclickredirect=1&uuid=04ByiKcxnUnyClnOp3rDzg
The roof must be done with plasticard (better than 3 d printing for curve roof !)
Postby rue_d_etropal » Sun Feb 21, 2016 10:50 am
Frank , I had assumed you were only interested in smaller locos, but most of the wagons , except the baggage car, are bogied. I have seen that in the Decauville catalogue book.
As for roof, I often use simple cheap(Free) card, which sticks to the 3D printed plastic OK(especially if you are less concerned about finish on plastics such as WSF). For small wagons, the cost of a 3D printed roof is very little though, and unless there is a lot of small detail, it is easy to smooth down. Got onto that site, but it as not showing picture, and it took a time to load on my computer.
franckcombe
Postby franckcombe » Tue Feb 23, 2016 4:32 pm
Today I start to buid the pechot's trucks from meridian model kit.
Postby rue_d_etropal » Wed Feb 24, 2016 1:59 pm
The Pechot wagon is my favourite of all the wagon used in WW1, although it was designed before. It was first bogie(1/35th scale) I did for 3D printing. The article in Voie Libre used the Meridian bogies and my wagon body. I now have the bogie in OO9, but ideally it needs more detail, and there is still the problem of matching width to track gauge.
franckcombe
Postby franckcombe » Wed Mar 09, 2016 7:14 am
My friend Jean-Pierre prints the rolling stock as a test.
Here the result
franckcombe
Postby franckcombe » Fri Mar 18, 2016 7:12 am
franckcombe
Postby franckcombe » Sat Apr 02, 2016 7:00 pm
I do some progress on my layout. I finish the building with the first coat of primer. The building will look like the building of the backdrops with trace of soil. I paint the soil before adding the sand, the grass, cactus and palm tree of course... I cast and paint the stones. I am happy with the result wich look like what I have in my mind.
Postby PeterH » Sat Apr 02, 2016 8:48 pm
Nice. I like how your layout is coming together. I can feel the heat of the wind off the sand.
franckcombe
Postby franckcombe » Wed Apr 06, 2016 2:52 pm
I have finish to paint and weather the buildings.
franckcombe
Postby franckcombe » Wed May 11, 2016 2:26 pm
I do little progress on the luggage car.
Postby rue_d_etropal » Thu May 12, 2016 11:02 pm
looking good Franck. Just wondering, are you planning to do any of the bigger wagons?
I know the Mallet is too big for your layout, but my 3D printed version of the body is now available, so if anyone else is inspired to model the lines in Morocco........
franckcombe
Postby franckcombe » Fri May 13, 2016 7:30 am
Hi Simon,
No I am not planning any bigger wagon.
Postby rue_d_etropal » Sat May 14, 2016 8:16 pm
Thanks Franck, I may be interested in doing some myself, when I find time.Too many ideas!
franckcombe
Postby franckcombe » Mon May 16, 2016 6:51 am
Hi Simon,
Now if you want to reproduce some rolling stock of Morocco I could be interested.
The problem is always the lack of times.
Postby rue_d_etropal » Mon May 16, 2016 9:15 am
Time is the big deciding factor. I have done the Mallet for 3D printing, so next step would be wagons and coaches. The Decauville catalogue does have decent drawings, so when(?) I might get down to doing the designs. At the moment I am only a short way(but it has already taken a long time) into project for modular buildings system. Had not appreciated how many variations there could be , even with a simple design!
franckcombe
Postby franckcombe » Thu Jul 07, 2016 4:02 pm
I have done a long pause because I'm doing in parallel an us ho layout.
I work hard to finish 135 trees for the oasis.
I bought cheap tree from ebay china and I modified the truck and the palm. Then I paint with humbrol enamel and I use weathering powder.
Postby Jon Randall » Mon Jul 25, 2016 12:47 pm
Impressive work both quality and quantity 8)
Postby Nevadablue » Tue Jul 26, 2016 2:50 am
Franck, the chinese palms look really good. Interesting idea, modifying those.
DCRFAN 3
Postby DCRFAN 3 » Thu Jul 28, 2016 12:27 am
Very impressive tree modelling. I well know how a layout eats up all the trees you make. This one has 42 trees in just under 1 m diameter layout.
http://forum.gn15.info/viewtopic.php?f= ... &start=125
Postby rue_d_etropal » Thu Jul 28, 2016 7:33 am
I used not to be a fan of shop bought model trees on layouts, but when I had a load of cheap ones from a magazine I used them to build forest on one layout. What surprised me was how many could be fitted in the space and as a group were quite effective. I also have some cheap Chinese palm trees like ones above, and find them quite effective if used in odd spots, either within other trees or on their own.
DuffieldBank
Postby DuffieldBank » Wed Sep 21, 2016 12:54 pm
Would you have a link to the Ebay seller for those trees?
C.
