If you have errors use Minimumgauge.info
Where I come clean and explain what I've done (moving posts around and the like).
Postby tebee » Mon Dec 08, 2014 9:36 am
If you are receiving errors trying to access the forum please try using http://minimumgauge.info rather than gn15.Info.
There seems to have been an error is the transfer of the DNS for this to the new site - we are looking into this, it may clear itself up in time.
Re: If you have errors use Minimumgauge.info
Postby Gerry Bullock » Mon Dec 08, 2014 12:44 pm
Slightly worse than that Tom; all links in VE & Loco Shed and for that matter in any thread now get a 403 message.
I also have Gn15.info Business Cards that I give out at shows, a number of other UK Members also have a few of these.
Having said that once one gets accustomed to Gnew format it looks great, many thanks for taking over the baton and long may you hold onto it. :D
Emrys
Interests: Model railways, photography, website design
Postby Emrys » Mon Dec 08, 2014 2:40 pm
Once the DNS is working as expected then links within the forum should start working again.
The situation we currently have is that even though both URLs are set up identically, minimumgauge.info is behaving nicely and is pointing at Tom's hosting while gn15.info is trying to point at both Tom's hosting and my hosting at the same time. This is not helpful and is, we suspect, causing those pesky "403 Forbidden" errors.
The best course of action for now is to wait for the DNS to propagate completely. Even if this doesn't fix all the errors (and it should), we'll be in a much better position to fix any lingering quirks once everyone's ISP is looking in the right place for the files.
Emrys Hopkins
Postby Thorness » Mon Dec 08, 2014 8:47 pm
Great work guys, I'm sure you will get it sorted!!
Thank you!
Postby tebee » Mon Dec 08, 2014 11:49 pm
I think all errors should be out of the system now and you should not see the 403 errors.
Let me know if you are still having problems.
martin
Postby martin » Tue Dec 09, 2014 12:57 am
Is the photo hosting known to be down or do I just have a stubborn ISP?
"I cannot connect to the database because: Access denied for user 'heywood_forum'@'localhost' (using password: YES)"
http://my.gn15.info/
Postby tebee » Tue Dec 09, 2014 1:35 am
yes I have changed a few things that will break this I now realize
Will try to fix tomorrow.
Postby Nevadablue » Tue Dec 09, 2014 3:23 am
I hope everyone is patient. This process isn't an easy one. I lost access again this evening for a while. No biggie. Tom will win and we ALL will win. Hang in there. :D
Larry
Interests: Gn15 micro
Postby Larry » Tue Dec 09, 2014 7:03 am
There's another error, Tom.
The arrows on your avatar seem to be pointing the wrong way. ;)
Postby Gerry Bullock » Tue Dec 09, 2014 4:53 pm
Hi Tom,
You probably have enough issues however here are a couple more:
If you find an image on the web that links to minimumgauge.info you get this message when you try to view page:
86.176.18.60/viewtopic.php?t=5188&sid=0ccb2c0f17128036b8fdea25d95a61b6
I've tried a couple and similar message occurs however any image linking to Gn15.info does enable a page view.
Minor one the users on line WAS showing 0 when I was on-line now seems OK.
Correction zero is shown against individual thread whereas the Forum count is working.
martin
Postby martin » Wed Dec 10, 2014 3:04 pm
I can now load the my.gn15.info page but it refuses to accept my password, is this still something that's ongoing?
Postby tebee » Wed Dec 10, 2014 3:14 pm
yes - the format the password is stored in has changed - I need to re-write the code that checks it and it's that is taking longer than I thought.
Having problems getting my programming head going again , not written much code last few years, though I used to do it all day long.
Have a few of my paying jobs and other things I need to do here getting in the way as well.
Postby Nevadablue » Wed Dec 10, 2014 4:03 pm
I'm just happy the forum is back again. :D
Return to “Things I've done”
