Tobar Station, my 2015 "1915" Challenge Entry
Re: Tobar Station, my 2015 "1915" Challenge Entry
Postby docnjoj » Mon Feb 01, 2016 3:19 pm
Any way you can lower the gearing for that chassis. Some of those 80:1 Grandtline ones would crawl, and they are not too expensive. The ones with those ho diesels have the whole kit at $30-40. NOt dirt cheap but can go as low as 160:1 gearing and including the motor. Ebay has them fairly cheap.
Just sayin'
Postby Nevadablue » Mon Feb 01, 2016 11:22 pm
I probably won't mess with that one. Not easy to change and I glued some things inside that should not have been glued. No real way to take it apart to change much. I'll just use that little loco for a backup. It was made of nothing for nothing, all salvaged stuff.
Return to “Challengnes”
