Powering a 16mm body
BarryL
Postby BarryL » Mon Oct 05, 2015 9:55 pm
The attached picture is of my 16mm Simplex. I have a number of these kits and fancy using one on 00 track. Not strictly GN15 but closeish. What is the best and cheap way to power it as I have no knowledge of what is available other than Hornby chassis.
Ta!
Barry
kevo
Re: Powering a 16mm body
Postby kevo » Tue Oct 06, 2015 9:58 pm
hi barry nice look ing simplex . ive used a bachmann 0n30 tram power unit in my gn 15 simplex hope that is of help or there is the common (spud unit] tenshodo motor bogie
kevin piper
BarryL
Postby BarryL » Wed Oct 07, 2015 3:23 am
I'll have a look at those. Thanks Kevo
Postby KEG » Wed Oct 07, 2015 7:33 am
Within the many thousands of contributions in this forume almost every available drive or chassis has been used and tested.
So it is very easy, to gain the nessessary knowledge. The search function of this forum might be helpful.
If somenone is asking for a suitable drive for a model, the least I´d except, to get informations about some of the basic dimensions.
I can not really believe, that a 16mm scale Simplex still fits in the category of Gn15. Better in "Seize does not matter"
Be careful when asking for cheap solutions. Have a look for the cheap solutions proposed in here in the past. Most of them do not run very well,
tend to stall or race along the track. In many cases, you never here of the cheap stuff any more.
Look for quality. In the long run it might cost you a few Pounds, Euro, Dollars more, but you´ll have a chance, to enjoy them for a very long time.
