Light weight bridges
Postby rue_d_etropal » Mon Nov 07, 2016 11:21 am
After looking at some photos, I am wondering about construction of light weight, often military built narrow gauge railways.
Early bridges were typically wooden, and track was sleepered. On later beidges the supports might still be wooden, but longitudinal metal girders were used. Some bridges had more substantial supports, and as there were so string often still exist.
Anyway, my question is about how the sleepers were(if at all) attached to the longitudinal girders.
Makes no difference in a model, just wondering.
Re: Light weight bridges
Postby chris69 » Mon Nov 07, 2016 8:12 pm
After WWII a lot of BAILEY BRIDGE Elements found their way in the NG field.
They where cheap as surplus and all over the place. On top of that,
light weight and easy to assemble without the need for heavy lifting gear.
Postby rue_d_etropal » Mon Nov 07, 2016 9:13 pm
The Bailey bridge is more complex than the bridges I mean. In the book on Longmoor it shows them building simple bridges with longitudinal metal beams and sleepered track on to. Just wondering if it was fixed in place. This was for standard gauge but it was also used for narrow gauge.
Return to “Blether”
