Pauls Card Challenge Layout
SOUTHPASS
Interests: Trains and cars.
Postby SOUTHPASS » Mon Oct 15, 2007 9:26 pm
G,day....That style was also very popular here in Australia and can still be found in the southern highlands on stockmans shacks.
The flash ones have a cast iron wood fired stove in them :)
.....WARNING....
1:24 scale 16.5mm gauge.
Have a good one....John B.
Postby Steve Bennett » Tue Oct 16, 2007 12:00 am
SOUTHPASS wrote:The flash ones have a cast iron wood fired stove in them :)
:lol: can just imagine that :lol:
Thinking about it, I think I have seen similar designs for smoking fish, probably not related though :) .
Jblair
Interests: Narrow Gauge trains.
Postby Jblair » Tue Oct 16, 2007 12:47 am
Haven't got picture exactly like what DCRfan has mentioned. But the style he has done is very common also in Australia during the logging days. But a very close version is the following which is one of the Stockmans shacks in the Victorian hi-country which southpass mentions. Many of them may have been burnt down due to the recent large fires in the area! These are certainly not used to smoke fish however! :lol:
Jarrod Blair
Melbourne, Australia
Postby Steve Bennett » Tue Oct 16, 2007 1:05 am
Jblair wrote:But a very close version is the following which is one of the Stockmans shacks in the Victorian hi-country which southpass mentions.
That building would make a very nice model aswell. Nice and simple, would look at home just about anywhere around the globe. Think that may go in the inspiration folder :wink: .
Postby DCRfan » Tue Oct 16, 2007 5:36 am
This what I had in mind
Postby Steve Bennett » Tue Oct 16, 2007 8:32 am
Ooooh, I like that one too :roll:
Korschtal
Postby Korschtal » Tue Oct 16, 2007 8:42 am
I like the way that even the dog is watching the camera...
Andy in Stuttgart
www.korschtal.wordpress.com
Postby Gerry Bullock » Tue Oct 16, 2007 11:09 am
DCRfan wrote:The chimney is a common design dating back to the first European settlement in NZ. Originally built using green slab wood later replaced by corrugated iron.
You say European Paul BUT that design of Chimney I can find nowhere in the UK, maybe it is of French origin or New World :?:
Postby scott b » Tue Oct 16, 2007 12:11 pm
Not from this new world, can`t make a step without stumbling over rock so thats what chimneys are made of around here.
That is begging to be modeled, I think the dog does make the scene though, that and the dude with the gun, "are you from the bank?"
Scott
Geno6309
Interests: NG,Sports Cars,Anything with 'fiddly bits' inside
Postby Geno6309 » Tue Oct 16, 2007 4:47 pm
I'm figuring there are a lot of high speed winds in the area. Small outlet at the top to keep the draft from sucking the windows and doors in. Another bit of evidence is the wind break on the right end of the porch. Keeps the wind from blowing G'ma down the road.
"I'm not building a model of a railroad. I'm building a caricature of one." Bill Livingston, Venango Valley RR, RMC 1971
Words to live by.
Gene Walker
www.fcdetc.blogspot.com
Postby DCRfan » Thu Oct 18, 2007 8:46 am
Spent a few hours with a bread knife and a hot glue gun making a box designed to carry and display the layout.
Luckly a monthly pallet sized delivery of medical supplies provides a ready supply of cardboard :D I plan to add inner walls diagonally across the corners to provide storage pockets and increase rigidity of the structure.
Gavin Sowry
Postby Gavin Sowry » Thu Oct 18, 2007 7:57 pm
:twisted: That ain't a pizza...it's a flamin' birthday cake :!:
:idea: Second thoughts, add a chin strap, and you missus can wear it as a hat in the Wearable Arts Awards. 8) 8) 8)
Gavin Sowry
Gn15 Gnu Zealand
Postby DCRfan » Fri Oct 19, 2007 4:47 am
Gavin Sowry wrote:Second thoughts, add a chin strap, and you missus can wear it as a hat in the Wearable Arts Awards. 8) 8) 8)
Won't suggest that as then she will want gnew shoes as well:shock: . I'm not making them from cardboard :lol:
Postby michael » Fri Oct 19, 2007 5:40 am
Love the photo of the corrugated building... "vernacular architecture" is wot it is!
Postby DCRfan » Fri Oct 19, 2007 9:47 am
This is the sort of scene I'm trying to recreate on the shed side of the pizza 8) Less the page fold down the centre of course :oops:
Rockley Bottom
Interests: NG railways
Postby Rockley Bottom » Fri Oct 19, 2007 11:51 am
Great layout , terrific atmosphere :!: :!:
Well done
Postby DCRfan » Sat Oct 27, 2007 12:27 am
Setting up the control for the single set of points has been frustrating. After realising the throw of the blades was more than the movement of the standard electrical switch I was using to switch power and control the blades a call from Gavin last night put be on the right track. It sure doesn't look pretty but it works.
Now to figure out the camouflage.
Rockley Bottom
Postby Rockley Bottom » Sat Oct 27, 2007 2:53 am
neat solution :!:
It is all to do with levers :) :)
A hollow pile of logs on top os the switch or a scrub bush infront of it
may be possoble solutions.
Is the switch blade hinged, and if so is it on top of the sleeper. :?:
Postby DCRfan » Sat Oct 27, 2007 6:07 am
Rockley Bottom wrote:neat solution :!:
Yeah a pile of logs was the sort of thing I was thinking of.
The fixed ends of the blades are slipped into rail joiners that have been slightly widened and the blades are prevented from sliding out by thin wire with the ends soldered to the blades and the fixed rail. The other end of the blades are held in gauge by the tie bar with is attached to the blades by brass pins soldered to the rail.
MickT
Postby MickT » Mon Oct 29, 2007 9:51 am
DCRfan wrote:This is the sort of scene I'm trying to recreate on the shed side of the pizza 8) Less the page fold down the centre of course :oops:
Ah, and I thought that it was a representation of the International Date Line......
Won't you have to turn the picture the other way up to make it correct for your part of the world as well?
:lol: :D
Mick
Postby DCRfan » Mon Oct 29, 2007 11:45 am
MickT wrote:Ah, and I thought that it was a representation of the International Date Line......
:lol: :D
Mick
It has had a special spell from a well known wizard to make it look right no matter where in the world you view it :wink:
Postby DCRfan » Mon Oct 29, 2007 11:49 am
I've decided the open fronted shed looked a little too contrived and unprototypical so the front is being walled in and fair few new ferns planted but they just seen to get swallowed up.
andrew milner
Postby andrew milner » Mon Oct 29, 2007 3:29 pm
The porch on the front of the building (photo with dog :D ) would be a nice compromise. You are going to need a lot of ferns to cover all that ground :cry: Could you fake some in the middle and just use the detailed ones near the edges?
Postby DCRfan » Wed Nov 07, 2007 5:25 am
The cardboard shanty hut and head office of the as yet named Silverpine Company has gone (or it fell down, I'm not saying :lol:) to be replaced by this bright shiny new portable sawmill :wink:
Postby Steve Bennett » Wed Nov 07, 2007 10:39 am
Far too clean Paul, but for how long :lol: .
Users browsing this forum: No registered users and 15 guests
