(F) Two Bridge curve
John S
Interests: 09 & DCC
Postby John S » Mon Aug 29, 2011 7:43 pm
Take one APA box and....................... :wink:
Postby KEG » Tue Aug 30, 2011 2:20 pm
John's cut up Apa Box for a 90 Degree turn is brilliant. Noticed the round edge as well.
I came up with a very tight U-turn, which I am not too happy with.
Since I paid for the lids, I plan to use them.
John S
Interests: 09 & DCC
Postby John S » Wed Aug 31, 2011 3:55 pm
Gents, in reference to the questions,
Bob, the idea behind the two halves (which incidentally now feature elsewhere!) was to see if it was possible to fit a curve.
I used a pair of Hornby R605 double curve 1st radius, as ever a compromise between what would fit in the box, what was likely to be run, and as the challenge is to build within the box, and utilising all the original box and lid, the idea seems to work!.
Juergen, mainly due to your tinkering with curves, set me on roll! Amazingly versatile these APA boxes have proven to be, not sure what the men in suits from IKEA would make of it though!
And Bob again... scenic, do like your culvert and Mozzers idea, and never having modelled water before going to give it a go.
Assistance needed for the following, somewhere there is lurking a picture of a rustic wooden railway bridge?
Help needed in locating the little rowing boat .
Going round the bend, has now become Two Bridge Curve...............................
John S
Interests: 09 & DCC
Postby John S » Wed Aug 31, 2011 7:01 pm
How about a coracle instead?
How rustic do you want the bridge to be?
Great idea the coracle, and as for rustic that is cool, save at bit on the materials for construction. :lol:
Postby Steve Bennett » Wed Aug 31, 2011 9:52 pm
Little rowing boats aren't actually that little in G scale. I doubt that one would fit on the corner module.
There are small rowing boats too :)
The one in this old pic is only a 9 footer.
Unfortunately my source for these doesn't stock them anymore. They used to be distributed to charity shops very cheaply and you could find them easily, but they seem to have disappeared completely now.
Postby Adrian » Thu Sep 01, 2011 10:53 pm
G'day All
Looking at the photo from Steve the construction of the boat doesn't look to daunting ...... given half a dozen sheets of your favouring modelling material a model should be only a evenings work or so :D :D :D
All one needs is a suitable set of plans which shouldn't be to difficult to produce if one has a sample to give the required dimensions.
Postby Adrian » Fri Sep 02, 2011 4:25 am
G'day again
Just been playing with 'Paint' and produced a BMP of a 10 foot row boat, ( sort of ).
Others more knowledgeable of thing marine might sneer but it suits my needs.
I want a row-boat or two in the future on my pier railway so I will be using this plan to give me a starting point when I get around to building them, probably in thin ply.
I am not sure of the best way to post a BMP. But this will have to do as a starter. It may have to be resized to return it to 'G' scale.
(photobucket seems to have reduced it somehow and also converted it to a JPG but there is a scale to help you out if necessary)
This is a very quick mock-up to test the original plan together with an, as yet, unpainted Jon to see what it looked like in the flesh.
Hope that this is of some help to somebody out there.
Edit: Just done a quick test and if the file is opened in Paint it will need to be stretched to 200% to suit 'G' scale.
Postby Adrian » Sat Sep 03, 2011 12:40 am
G'day folks
Thanks for the kind words lads. I needed a set of plans anyway and the posting about boats set me in motion !
Andy A wrote:
I've had two goes at a power boat for it,
This is what I like about Paint:-
Just 5 mins. after reading the above I had modified the plan to produce a motor boat type deck using the original deck as a guide. Image
By the way Peter, Jon will not be piloting any boat again soon ...... he gets sea-sick :oops: :!: :oops: :!:
John S
Interests: 09 & DCC
Postby John S » Sun Sep 11, 2011 2:56 am
Update......
Two Bridge Curve, all wired up and tested. Coving complete, internal of box painted white, if dry later will apply the back scene colour, plus add a pelmet to the front.
Again been fiddling with battery powered stick on cupboard/shed led lights from Poundland, these are two for a pound! Same principle, remove the internals, and in this case remove the on board soldered resistor and replace with a higher value, this pair are driven from a PSU from our no longer provider of our internet service, nominal voltage 16v DC, PSU marked as 12v DC, have another pair to tinker with for the other curve, again will try a lower value resistor.
John S
Interests: 09 & DCC
Postby John S » Tue Sep 13, 2011 11:17 am
Clean forgot, 99p bid on eBay, one Playmobil Boat, less Jon!
and
Bit of work required, repaint the boat, knock up a small jetty etc, should fit in as snug as a bug in a rug.
Return to “GnAtterBoxes”
