Since moving over this side of the pond, it is easier to locate and purchase American models for my forays into engine designs for the Much Gnattering & Far Twaddle Light Railway.
I purchased a Bachmann 0-6-0 tender engine with a view to making another engine. First picture below:
This first view shows a plan with the wheel spacings and chassis size. From this a plan can be put together to check proportions/viability.
This view shows the loco body removed and the DCC decoder. I like the complex valve gear on this model. The engine will be called "Pocahontas" and I like the idea of when she moves, the valve gear and wheel movement will convey a beautiful and graceful feminine sort of wiggle.
Progress so far with the GN15 body on the chassis. I have bitten the bullet and will make her as a tender engine, rather than taking the easy option by concealing the chassis/motor with side tanks. The curves on the tender make it too good not to use.
This view shows the "Whimsical Victorian Femine Engine Style" that I have chosen for "Pocahontas" - lots of panelling and curves. I think the sheet concealing the chassis will work, and the wood encased boiler will be a joy and challenge to paint. I have used some of Mike Rayner's excellent Smallbrook Studios parts, including a Nellie spectacle plate and Columbine dome to keep her in line with the rest of the MG & FT fleet. I promise one day to build somewhere to run them all on.
Thats all for now.
Kind regards
Mark
