Espalier Apples
Espalier Apples
Postby Gerry Bullock » Mon Jan 02, 2012 10:20 pm
I've started constructing some espaliers for the back scene wall on Gneiss Cider. They're made with a German plastic deciduous tree for N/Z scale.
Two of the plastic trees are needed to make up a single espalier.
First photo (2nd espalier) now shows first step in the construction process which involves adhering the two main branches of tree to create a thicker trunk. Trunk is then covered in Vallejo modelling paste.
I've used florist wire between the two trunks to provide a substantial 'leg' to fit into baseboard.
Addition of a brown crepe tape wrapped around the paste, adhered using PVA.
Next step is to paint the espalier prior to adding leaves and apples.
Postby Gerry Bullock » Tue Jan 03, 2012 12:38 pm
Now painted, progress will now depend upon arrival of leaf punch.
I still need to make at least two more.
only15
Interests: All things Minimum!
Postby only15 » Tue Jan 03, 2012 9:17 pm
Looks good!
Can't wait to see it foilaged up!
Nathan
Remember, the light at the end of the tunnel may very well be an on-coming train! ;)
Taylor Creek Tramway - 35n12
21 years young,
Tasmania, Australia.
