[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 492: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 113: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
Simple Shuttle controller - The GnATTERbox
Postby Glen A » Wed Jan 02, 2013 4:03 am
With the new configuration of modules I needed to be able to drive two trains at once myself.
So I built a shuttle controller using a latching relay.
The idea is I drive one train and while I'm shunting at one end, I can push a button and the other train will shuttle down the track and then come back and stop.
I also made a option so I could leave a train continuoiusly running backwards and forwards between two reed switches by mounting another reed switch on a different siding.
I used just a few parts:
12v latching relay
a couple of glass reed switches
small magnet (mounted under engine or wagon)
push button
diode
Its so simple to build anyone can have a go.
The 12v latching relay (middle) cost me NZ$15 (about UK 5 pounds),
the reed switch (bottom) NZ$2.50ea and diode (top) just 15 cents.
Here is the wiring for the relay.
A short burst of 12v across the top two pins will hold the relay in one position. And a burst on the next two will move it to the other position and hold it there.
Now you can make a 'normal' relay 'latch' by adding a whole lot of other parts, but I wanted a simple job. :roll:
For a continuous run the reed switches get mounted in the track like this:
Or for an 'out and back' something like this (you will need to test the diode in both directions to find out which way is right) :
Or if you are a bit more clever and want both options:
So here it is wired up under the module, so I can plug in the controllers and power supply into it:
The reed switch mounted in the track (and painted grey to hide it):
Magnet mounted under a wagon, with some blu-tack.
The magnets out of old computers CD and DVD drives are really small and strong:
And here is my train ready for hours of fun shuttling back and forwards: :D
Postby michael » Wed Jan 02, 2013 4:58 am
Glen that is very interesting.
Postby Artizen » Wed Jan 02, 2013 6:50 am
I guess it would be even more interesting if I knew what it all meant!!!!!
I am assuming that the magnet somehow triggers the thingy between the rails so that polarity is reversed?
Postby Glen A » Thu Jan 03, 2013 1:25 am
Postby Adrian » Thu Jan 03, 2013 1:26 am
Postby Artizen » Thu Jan 03, 2013 4:14 am
Postby Glen A » Thu Jan 03, 2013 4:41 am
Prof Klyzlr
...the magnets...
Postby Prof Klyzlr » Fri Jan 04, 2013 8:18 am
Dear Gn15 fans,
Simple analog DC shuttles have been a bread-n-butter piece of many show layout builders toolkits for many years now.
However, given the need to run any loco (without modification, reconfig, or reporgramming), in any direction, at any orientation, at any time, and in some cases suddenly press-gang brand-new or "foreign" equipment into service on the shuttle route, any method which requires modification to operate (such as mounting magnets on cars or locos) is a hamstring I know I'd rather not have to deal with.
As an alternative, a "dumb timer" 555-based reverser and a diode "stopping section" at each end achieves the same basic results, without requiring any mods to the locos or rollingstock...
http://home.cogeco.ca/~rpaisley4/AutoRevCheap.html
Given that the reverser relay is a "pass thru" situation, it can be effectively "plugged in circuit" between any analog throttle/controller and track feed, IE entirely adaptable to any existing layout or system.
For bonus points, simply dropping power to the reverser circuit drops the relay to a known predictable state, so a single SPST "manual/auto" switch is all that's needed to switch on-the-fly to/from "shuttle" and "direct manual drive" mode...
Just another way to skin the same cat... ;-)
Happy Modelling,
Aim to Improve,
Prof Klyzlr
PS Units similar to the Rob Paisley circuit are available commercially here in Aust from Anton's Trains, and in the UK from GaugeMaster.
http://www.gaugemaster.com/item_details ... augemaster SS-1
Circuitron also do the AR1 and AR2 units which are slightly different, and use light-dependent detectors at the end-of-run
http://www.circuitron.com/index_files/cat/301CAT.pdf
check Page 29 by he printed page #s, or page 42 as indicated by PDF Reader
PPS: now, if only DCC were capable of the same trick,
while forfilling all of the established operational and practical criteria noted above... ;-)
Happy Modelling,
Aim to Improve,
Prof Klyzlr
Postby rue_d_etropal » Fri Jan 04, 2013 4:50 pm
The diode and timer is the way I have been operating shuttles for years. I have some relatively cheap units bought a few years ago and just extracted from storage. Fortunately they worked(one failure out of 5), but if I have a problem I will switch to my ever trustworthy Gaugemaster unit.
Very useful at exhibitions. I am planning to use it on my APA module when it is exhibited as part of the French challenge in October.
I am also exhibiting it at a one day show this month in Blackburn, so I will be able to see how well it runs. The module is wired so the sidings at back can be operated separately from the line at the front, which operates as a shuttle.
Tested module last night in operators mode, ie from back, and will need to sort out some lighting just in case. Loads for wagons also need to be tested, either loose granules representing grapes, or a solid infill which can be easily removed. Depends on time, so will try with loose granules/seeds first.
I am using the Bachmann HO GE70 locos as basis for my Gn15 locos. As they are DCC onboard, they need to power up before moving off . Nice slow runners as well.
Agree it is a pity there is nothing easy for DCC to operate a shuttle. Suppose the answer is to have the lines split so the shuttle section can be run on analogue and rest on DCC. I think that would work on my module, but no point as only one loco on shunting lines.
Postby Glen A » Fri Jan 04, 2013 7:26 pm
Very good, diode and timer. Yes that normally works.
However in my instance I could not put a dead section with diode in one end due to the other train needing to run well into the dead section to get the wagon lined up with the dump shoot. (sorry, I should have made that clearer at the start).
bandmbill
Interests: O9 Gn15 G9
Postby bandmbill » Fri Jan 04, 2013 8:27 pm
Using DCC since 1997 wherever I can!
Postby rue_d_etropal » Fri Jan 04, 2013 9:43 pm
Postby Adrian » Sat Jan 05, 2013 3:17 am
Prof Klyzlr
Postby Prof Klyzlr » Sat Jan 05, 2013 4:27 am
Happy Modelling,
Aim to Improve,
Prof Klyzlr
Postby Gerry Bullock » Thu Jan 10, 2013 11:43 am
Here's the unit I plan to use Glen (You'll know where :wink: ):
Prof Klyzlr
Postby Prof Klyzlr » Thu Jan 10, 2013 11:50 am
Dear Gerry,
Love the way that some people consider basic circuits soo "proprietary" that they must scrub off any and all ID markings on the components...
Seems to be a curiously UK thing, I've noted the same thing with items sold by Gaugemaster...
Happy Modelling,
Aim to Improve,
Prof Klyzlr
Happy Modelling,
Aim to Improve,
Prof Klyzlr
bonneville
Interests: All things narrow gauge and crusty.
Postby bonneville » Thu Jan 10, 2013 12:42 pm
I expect we could all write volumes about curiously British model railway habits and thinking, maybe a future subject for the Blether columns maybe? :lol:
Alex Housego.
In Rust, I Trust.
Postby Adrian » Fri Jan 11, 2013 1:41 am
