Weed Sprayer
JeffSaxton
Weed Sprayer
Postby JeffSaxton » Sun Feb 10, 2013 9:01 pm
Hello, All;
I don't think this one has been seen yet, I built it back in 2005 when I couldn't access the Forum.
The car is a free-lance weed sprayer, based on one of my Hudson pattern skip frames (see this thread for chassis details http://forum.gn15.info/viewtopic.php?t=8967).
The sprayer itself is, IIRC:
Two air tanks from the old MDC 'Hustler' in G scale -- a resin block from a commerical project (bolster snubber from a GE "Genesis" loco in 1:32) -- a headlight from the same 'Hustler' kit -- a Bandai 1:48 wooden box from an old German 'Maultier' kit -- piping from a Bachmann 1:20 Shay cab -- lever from an Atlas O scale switchtower -- and the sprayer nozzle head is a handrail piece with the ball ends. The paint is kinda lumpy, I didn't have an airbrush compressor at the time, but heavy weathering will hide those sins.
The idea is it would take a steam connection from the locomotive via hose, to operate the pump itself.
Just noticed this frame uses the laser cut pedestals I experimented with.
Jeff Saxton
Postby Gerry Bullock » Sun Feb 10, 2013 9:15 pm
I like it Jeff. 8)
Postby Little Andi. » Mon Feb 11, 2013 8:35 am
Weed Sprayer - [smacks forehead], Why didn't I think of that??
A little while ago I was knocking up little utility type wagons and searching around for ideas that would translate into a "works train"!! ... I have a Power truck, a Compressor truck a Crane and now a "Weed wagon" .................. a hearty "thank you" for making the idea available for stealing [smiles]!
Cheers chap ...............
JeffSaxton
Postby JeffSaxton » Mon Feb 11, 2013 4:34 pm
Not sure how British it is, but in the States, several narrow gauge lines had "weed burners" as well. Small tank of flammable stuff, sprayed through a sheet metal shroud held over the track a few inches ...
Jeff Saxton
WaterleyShunter
Postby WaterleyShunter » Wed Feb 13, 2013 4:00 pm
JeffSaxton wrote:Not sure how British it is, but in the States, several narrow gauge lines had "weed burners" as well. Small tank of flammable stuff, sprayed through a sheet metal shroud held over the track a few inches ...
:shock:
How did they make sure the burner did not set fire to the (presumably wooden) sleepers? :?:
Re: !!!
Postby More_Cats_Than_Sense » Wed Feb 13, 2013 5:27 pm
WaterleyShunter wrote:
:shock:
Same way you bake a 'Baked Alaska' or the way you can solder next to a previous solder joint, high heat and short time ;)
JeffSaxton
Postby JeffSaxton » Thu Feb 14, 2013 4:28 am
Barry is correct. The photos I have seen show a rather large contraption, similar to a vent hood over a large oven. I suppose the combustion takes place at the upper reaches of the hood, and the flames merely singe the grass and weeds away. Of course, this system also requires a small tankcar of water to go along behind the train and put out any fires as well!
I can't find a picture online, maybe someone else can, but the Pajaro Valley Consolidated had such a car, actually, it was a combined sprayer and burner.
I suppose a modern car might use a huge garden strimmer? :D
(Now I'll be humming the "Arnold Rimmer" song all night).
Jeff Saxton
Users browsing this forum: Bing [Bot] and 16 guests
